FireGuard
Nov 21, 2022Explorer II
A lot of good info by other members so I won’t repeat it.
If you don’t want to remove the lift I would focus on the tires.
If you have a large soft sidewall tire like a C or D rated you can improve your setup.
I would go back to stock size (275 or 285 /70/17) on the factory wheel or equivalent.
You can also get some better tires with a stiff sidewall and way more capacity than many big tires used on lifted trucks.
The right tire will make a HUGE difference in stability.
Good luck.
Good luck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
