fj12ryder
Nov 20, 2021Explorer III
CA Traveler wrote:That's what I did on our toyhauler. The wall blocked the pump switch when the toys were loaded, so I just added an easy to reach rocker switch, wired in with the original.
How about adding an accessable switch?
Normally OK to leave it on but there are several reasons why the pump could run dry, probably not the best scenario. And if it does the pump may well draw more amps than the TV charge line can supply which is also not desirable.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
