GoPackGo's avatar
GoPackGo
TowMax Tires
My rig is exactly one year old and has been pulled around 9 - 10,000 miles. I just pulled into a campground here in Wyoming and noticed one tire looked kinda low. Pulled the wheel off and saw that the outer rubber was cut open about 3 inches on the inner side of the tire and had separated. This was not due to hitting anything. I think it blew 'softly' and slowly leaked down over several miles as opposed to 'explosively'. The tread also seemed to be raised upward and the mechanic said that meant it was separating internally. It still had 20 pounds of pressure in it. I figure that if I had driven too much further all the remaining air would have leaked out, putting the entire weight of the rig on that side onto the one remaining tire with possibly real ugly consequences.
I always run at 55-58 mph and always had the tires inflated to 80 pounds. Still had lots of tread. So they were not abused. I've read lots of tire posts on rv.net so I tried to keep an eye on them.
I had wanted to finish my traveling for this year (full timing) and then get new tires but NOT !
I understand that you can't judge when to replace an ST tire by the number of miles you put on them. But these TowMax tires seem to fail internally regardless of age or miles. Shouldn't I expect to get more then one year out of them ? No need to answer.
I really do think it should be illegal to sell (or install as OEM) TowMax tires. How can these things possibly be DOT approved ??
I now have 4 Maxxis M8008s ordered.
I'm not trying to restart the LT vs ST discussion. I've read lots of posts on the subject and made my decision. Maxxis ST tires seem to have a good reputation and owners seem to be happy with them.
OK, I feel better now.
Tim
