fj12ryder wrote:
Just out of curiosity, how far behind the rear axle is the hitch mounted? By that I mean where does the weight rest in the bed with respect to the rear axle. And where is your fresh water tank located?
Kind of hard to tell exactly, but the trailer looks pretty level to me.
Hitch/ball is roughly right over the axle, if not slightly ahead of.
I just looked under the camper and I think (it's all covered) the fresh water might actually be just behind the trailer axles. The overflow and main dump are there. The fuel cell is located under the garage, at the very back. The cleanouts are coming from above the axle and in front of the axle.
That makes me think the greys and black are actually towards the front of the camper.
This now makes me think I didn't have enough air in my airbags. Without the extra counterbalance of the bike at the back of the trailer, a lot more weight was on the truck than I originally though. I only had the fresh water partially full the first trip. With the bike that's putting almost 2K lbs behind the trailer axles.
I didn't try running pressure past 35 lbs since that worked the best on the first trip.
Specs list dry weight @ 12,400 with Pin @ 2300. The tag lists mine @ 13,200. With the generator my rough estimate on pin was 2,600.
I assume filled up and running without any toys I am 14,500 lbs with 3,200 pin. That should put it right around 22% which seems like where it should be. I realize these are assumptions on my part for weights based on literature.
