bbaker2001
Jun 03, 2017Explorer
tpms repeater
Have the TST507 tpms system. when traveling, not all the sensors show up. I have a 30ft 5er. do I need to install a repeater, and are there different brands
golf_bears wrote:What system are you using? If you're using a TST system, then an hour has elapsed before the beep. The last reading received from the sensor will be displayed until the alarm sounds. This takes about an hour.
When one of my sensor's signal is lost, I get a beep from the monitor as the monitor cycles to that sensor again. This doesn't take an hour on my system. It happens within a few minutes.
