bbaker2001
Jun 03, 2017Explorer
tpms repeater
Have the TST507 tpms system. when traveling, not all the sensors show up. I have a 30ft 5er. do I need to install a repeater, and are there different brands
rsg63 wrote:The monitor takes about an hour to alert you to a lost signal. You will see the last reading until the alarm sounds, then the reading blanks out. You can check this by turning the monitor on battery power and leaving the trailer, like when you go get fuel or food. You'll find an hour will elapse before the alarm sounds.
Yes, alarm and no signal. But...don't think the signal is lost for an hour prior to the alarm, only because the readings change constantly up to the point of an alarm. Unless of course the readings I'm seeing are historical and being fed to me over time, but that seems unlikely.
