A major problem with the TST system a loss of signal from a sensor will not be reported for 1 hour.
I had a Pressure Pro which I replaced with a TST system. I wish now I had kept the Pressure Pro.
I tow a utility trailer behind the 5th wheel so I needed something to increase the range of my system.
Pressure Pro has an external antenna part number ABPCA-SMA
Available here and other vendors.
AntennaThe antenna also works great with my TST system. Same antenna connection on the receiver.
I mounted the antenna under the rear of my truck on the factory trailer hitch.
What I like about the antenna no need for power and you never forget to turn it on like you may with a repeater.
