Bayley
Feb 23, 2018Explorer
TPMS Systems
I'm looking at adding a TPMS system to my rig. Based on cost and performance I've narrowed it down the EEZ-Tire and the Tire-Traker models. Does anyone have experience with these two products. As a...
fj12ryder wrote:Ron3rd wrote:You got it in one. :) It can take an hour before the readings drop off the screen, and you get an alert.
Are you saying the sensor could loose communication with the receiver but still show up on the screen and still be reporting PSI and Temps?
It happened to me after leaving a campground. I usually don't check the readings, rather I rely on the alerts. But I had Peggy watch the monitor run through the tires. Strangely 5 out of 6 tires had basically the same readings, with one that was substantially lower in pressure and temperature, and reading the same as when we left the campground. Just as I started to pull over to investigate the alarm sounded. It had been an hour since we had left the campground, and the monitor just then alerted that a sensor has been lost. As soon as we pulled over the sensor reconnected and showed the same readings as the other 5 tires. So it's a definite issue and has happened to other people too.
FWIW I believe that the TST system now comes standard with a repeater. When I bought mine the repeater was an extra cost option.
