avvidclif1 wrote:
With 2" between the tires I can't go anything larger in diameter and maintain adequate clearance. Most of the LT tires I've seen are larger in diameter.
I have done research on the tires and can find no brand that doesn't have detractors. At least with Carlisle I can get warranty service about anywhere.
That is a problem with most of the LT G-rated tires, however the Goodyear G614 has it's diameter listed as the same as the ST 235/80-16: 30.5". I went with the Sailun and it was an inch more in diameter than the Carlisles I replaced, so your clearance will preclude using those for sure. Sorry.
