ScottG
Jun 09, 2014Nomad
Do you get any kind of codes?
The only thing I can think of is a bad connection at the end opposite of the 7 pin connector (often just a wire nut) or the brake wire that passes from one side to the other through the axle has worn through inside the tube and is shorting to ground.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
