B-rad_Lee's avatar
B-rad_Lee
Trailer Lift Blocks
Hi I have a 2016 Fuzion 325 that is sitting a little nose high. I would like to add load leveling air bag on my 2011 Ford F350 which would push the the nose of the trailer higher so I am look at adding 2.5 lift blocks and want to see anyone has installed lift blocks on their toy hauler. I have 7.5" of clearance between the trailer and the bed rails. I could drop my hitch down by 1" but I would like keep the 7.5" of clearance. FYI... Fuzion's comes from the factory with the axes flipped.
  • tinner12002 wrote:
    Strabo wrote:
    lincster wrote:
    I had Weekend Warrior do essentially that at the factory, but I didn't add blocks, I had an entire section of 2" channel added the entire length of where the axle hangers are welded onto.
    Same here
    I hope it was tube and not channel. Using blocks is probably the easiest to do after the fact if done right!
    Yes, sorry, tube was used.
