opnspaces wrote:
How much room are you looking to gain?
Look under the trailer at the axles. If it has leaf springs and they are under the axle then you can add a kit to put the springs on top. This will gain you about 6 inches (the thickness of the axle plus the thickness of the spring pack) Dexter makes a kit for this.
Link to kit
Do remember that any other lift methods have to be divided in half. A tire that is one inch taller only lifts the trailer by 1/2 inch. It's the same with a longer shackle. A 1 inch longer shackle on one end of the spring pack adds only 1/2 inch to the ride height.
A longer shackle will lower the trailer.:)
