rhagfo
Dec 23, 2015Explorer III
Baja Man wrote:
I plugged in my trailer plug to truck receptacle. All lights work correctly except for the right rear taillight that I just replaced. The wires appear to be reversed. When running lights are on the stop (brighter filament)light is on making that taillight brighter than the other one.
I did replace the tail light housing and lens but there are only three wires (brown for running lights, Green for stop/turn, and white for ground. I even put the old housing back obn to check and still does not correct problem.
I also hooked up my boat to see if truck receptacle was wired OK and the lights work perfect.
I can't recall if the lights worked OK before since I only trailered once for a few miles.
If I reverse the brown and green wires at tailight, all works well. Not sure if that is the correct solution.
Help!!!
Thanks
Sounds like you have your answer!!!
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
