How do you stop your 5er from shaking when people walk. I block the wheels and put a tripod in the front and lower the jacks. It bad enough that when our 15lb. dog walks you can feel each step. Ple...
I have found that a lot of shaking comes from the "landing gear legs". If you pull the pin and drop legs, just before contact with ground, wiggle end at plate and you can see how much movement there is. What I do is once plate is in contact with ground, and there is a little weight on leg, I push one leg out and back and the other out and forward. This seems to help with shaking for me. Not a cure all, but it does help.
