Good afternoon fellow 5'ers. I am in the process of buying a used 5'er and would like to put new tires on it before I move it to it's new home since it has been sitting parked in the same spot for th...
If "E" rated tires, I'd steer clear of Carlisle tires and look at the Duravis R250, the Michelin XPS RIBS, (pricey but VERY good) or the Maxxis which you are comparing to the Carlisle...
I'd highly recommend an LT tire over the ST tires...stick around, you will get more comments:)
