bigdon68 wrote:
hone eagle wrote:
I air mine down ,if you don't it will bang hard on the pin box.
no harm done if you forget.
Just unhook as normal. I have the TS3 but the BD3 is no different when unhooking.
If you have the auto air leveling with the hitch (which is an option) then you may experience the hitch slamming up against the pin plate when you unhook. In that case you would need to air down the hitch.
Normally though - without this option -- unhook as normal.
bigdon68
Should of used more detail
lower legs until they are load bearing ,dump air in hitch now legs have all the weight .
dump air in truck suspension, unlatch (easy now with no load on pin)- roll forward .
Most of the time the trailer is perfectly level.
when its time to hook up reverse the procedure ,i seldom have to use the electric jack motors.
