jffnkrn's avatar
jffnkrn
transfer switch
Well very frustrated. So I will vent a bit. We had a travel trailer with 30 amp 120 service, had and still have my Honda EU 3000 IS and it did a great job handling the travel trailer with the transfer switch. wired in and all was great. Now, fifth wheel with 220 and 30 amp generator. So here goes. You can use the factory supplied plug/cord - 220 50 amp 4 wire and run everything in the coach. oh we only have one a/c so not a problem. have a 220 50 amp service at the house for shore power and still have my 3000 Honda generator. So transfer switch i had according to electrician will not work because of 220 shore power, 110 generator power and depending on what is being used in the coach could be over the amount for 110 and just right for 220. if you only use everything without the second a/c, then 30 amp service works great. BUT, i bought a 50 amp transfer switch from camping world, the guy drew a diagram on how to wire it so it will accept 50 amp shore power and 30 amp geny power. electrician says it won't work as if you hook up the terminals the way camping world says, jumper between L1 and L2 you will be connecting a neutral with a hot leg as the switch is already wired from the factory. So my delema. i want to have my cake and eat it too. hook up to 220 50 amps when i want, hook up to 30 amps as needed do to available power or use 30 amp 110 generator with a transfer switch. so not that everyone is confused, please give me your take on the situation if yo could. Good Luck & Be Safe ! ! !
