Tazz3069 wrote:
I installed a dual 30amp fuse inline already. I just needed to connect to the 120V input source. Tech Support is the one who told me to connect after the transfer switch. I dont think they understood that I have a generator in the unit.
Regardless whether there is a generator and/or transfer switch installed or not, I have never seen any 120 volt device on a travel trailer (with the sole exception of a transfer switch) that was not wired/connected post breaker via the main 120 volt breaker/distribution panel.
Why use inline fuses when you have a breaker/distribution panel?
EDIT: If you're talking about using inline fuses on the DC OUTput of the inverter/converter, please disregard 2nd paragraph.
