- kampinguruExplorerI have a 2000 7.3l F250 and have had the 6.0 oil cooler installed. You do not want to be at 240 for very long. Check the smell of your tranny fluid on the dipstick. If it smells burned, you have been too hot. I also have the BTS transmission installed and I do not see temps above 160 anymore. I run Scheffers synthetic fluid in the truck as well.
- el_RojoExplorerChange to synthetic fluids. They will run cooler.
- PuddlesExplorerIf your truck is a 2000 or older, Ford has a radiator available that will alow tranny oil to go thru it and be cooled... does a much better job than a air type cooler... I wouldn't like to see oil temps above 210 anytime. That cooler water in the bottom of a radiator is a life saver for the transmission.
- 0rionExplorerif it spiked to 240 on a hill and then came back down I wouldn't worry about it a whole bunch but I wouldn't want it to run there for any extended amount of time.
- cpaulsenExplorerIn your 4R100 trans...it should not be run @ 230 for any extended length of time. Check out the FTE forum. There is a trans engineer who posts there...Mark.
- Old-BiscuitExplorer IIIIIRC the OEM factory high oil temp alarm is 250* on my RAM
Hard pulls, high air temp and long grades I've never seen temps over 215*F
Had OEM alarm once backing 5'vr up long steep driveway...gauge reading 245*F
Found this on another forum.......posted back in 2011
Maximum transmission temperature
In the February 2011 issue of Trailer Life magazine RV Clinic in response to a reader about the maximum transmission temperature allowed in a 2009 Chevy Silverado, the Tech Team had this response.
“General Motors’ in-house towing team expert provided RV Clinic with this statement: The maximum allowable automatic transmission fluid temperature is dictated by the transmission oil itself. The oil begins to degrade significantly above 270 degrees Fahrenheit, so we design vehicles so that in all but the most extreme conditions, the fluid temperature in the transmission sump stays below 270 degrees F.
We allow for up to 285 degrees F in extreme conditions (i.e. towing a trailer with combination loaded at GCWR in Death Valley). But for customer usage anywhere else in the country, even at GCWR, transmission sump temperature should stay well below 270 degrees F. Above this point, certain internal components, such as seals, begin to disintegrate rather quickly. Although newer synthetic fluids can withstand higher temperatures we still recommend this (270F) as a maximum temperature. "
And this also was posted.....
a little research thinking that maybe GM was referring to new vehicles that are utilizing synthetic oil as all GM trucks do since GMT 900 in 2007 (much higher operating temps than traditional "dino" oil). I found that transmission oil starts breaking down prematurely at temps above 175, damage occurs above 300 to internal transmission components, and as high as 275 is allowable for all transmission fluids. However, it you run temps above 175 (as we all do towing our rigs) more frequent fluid and filter changes are required as outlined in the following chart (validated from a couple of sources):
175 degrees change every 100,000 miles
195 degrees change every 50,000 miles
215 degrees change every 25,000 miles
235 degrees change every 12,500 miles
255 degrees change every 6,520 miles
275 degrees change every 3,125 miles - pronstarExplorerDepends on the situation.
In city driving when the torque converter is unlocked, that should be your ceiling.
On the highway with the torque converter locked, that's way too high. - ScottGNomadA high of 240 isn't bad.
- blkdodgeExplorerSeems high to me. I run around 200 degrees
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 17, 2025
