Old-Biscuit
Feb 26, 2014Explorer III
That Travel Supreme weighs more 'dry' then your Cardinal does fully loaded.
It has a dry weight of 14,500# so that would roughly be 2900# dry pin weight.
Curb weight on your truck is around 3840# rear axle....RAWR is 6084# leaving 2244# minus hitch....2000#
Truck is only rated to tow 11,650# (properly equipped and using mfg. magical max tow rating system)
And it only has a GVWR of 8800#
You will be over gross, you will be over rear axle/rear tires, over tow capacity......
But it's flat........
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
