Me_Again
Feb 26, 2014Explorer III
Truck weighs around 7100-7200 ready to tow. Front axle is in the 4200-4400 range. So rear axle is less than 3K. It has the factory optional LT265's rated to 3415 each. That is why I said I would be good for a short flat haul like this up to around 3500 pin weight. It has the Camper option with rear overload springs similar to the 1T dually. Wind would not be my friend as it is a shorter Std Cab truck. Power is not a problem. Fresh custom tranny and triple disc TC.
The pictures I have found show the three axles set quite a ways back.
Just do not want to drive all the way over there and then not be able to move it.
Worst case it is 15K as sits and 25 percent pin weight and I am at 3750 pin weight.
Chris
Chris
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
