laknox
Dec 22, 2016Nomad
otrfun wrote:laknox wrote:23 MPG at 75 MPH is pretty darn good. Very possible it was due to aerodyanmics. However, depending on your route, it's possible elevation could have played a role, too. For instance, Phoenix is about 1,000 ft. lower in elevation than Tucson. I get 18-19 MPG with my Cummins, Tucson to Phoenix, and 16-17 MPG, Phoenix to Tucson.CampingN.C. wrote:Interestingly, the best mileage I've ever seen in my D'max was on a trip to CO several years ago, with a 14 cu ft chest freezer in the back, right up against the cab. I saw 23+ mpg while running 75 after DW told me that my fuel-saving 65 was too slow. :-) Surprised hell out of me, that's for sure. Simply =has= to be aerodynamics.
This is similar to an episode of Mythbusters years ago where they tested the theory of a trucks tailgate being down increased mileage. The myth was busted as the truck with the tailgate up had much better mpg.
I can't find the video on the net but I remember them doing test in wind tunnels and it clearly showed the difference.
Somewhat off topic but still interesting.
Lyle
Chandler to Cortez CO, via Gallup and Farmington; back via 4 Corners. Averaged about 22 for the entire trip. Normal highway, non-towing, is about 20-21...even with a clean K&N filter. I =did= use Diesel Kleen for the whole trip, so that may have helped a bit, too.
Lyle
About Fifth Wheel Group
