soje's avatar
soje
Travel trailer "vs" fith wheel --MPG to tow
How much difference in fuel MPG`S have you had with a bumper pull compared to the large wind resistance of a fiver?
I have noticed a high fuel consumption in a head wind.
Is it streamlining or lack there of that is to blame?
Feel like I am pulling a 13 ft high box at times.
I see trucks with all sorts of streamlining on the road.
JUST CURIOUS-not that I want a travel trailer/bumper pull unit.
  • I actually get better MPG towing my Columbus fiver than I did my 26' Jayco TT.
    I'm sure aerodynamics plays the biggest part. Towing the Jayco TT was like pulling a big square box down the road. This is with my 6.7 CTD.
  • I've pulled cargo trailers, travel trailers and fifth wheels. Sometimes the mileage is the same, sometimes it might vary by 2 mpg. Big deal.
    B.O.
  • Dont assume just because its taller a 5er has more air resistance than a TT.
    5er and TV act like a single large mass cutting through the air while TT and TV act like two separate masses with a lot of dirty air in between.
  • Ana
    Awful lot depends on what your pulling with. 4.10 rear end Cummins dually pulling 13,500 pounds I can get 11.5 between LaPine and Lakeview. 9.5 between Salem and Bend.
    You are pulling a 13' high box. Whatever part of the 5th wheel is above the truck acts like an air brake. Plus the extra weight.
  • With my ram 3500 drw 4x4 I went from getting 11mpg towing a 26ft 5000lb TT, to getting 9mpg pullling a 40ft 14000lb fiver..... not enough difference to make me worry any.
