webslave
Jun 28, 2014Explorer
Cummins12V98 wrote:kakampers wrote:
Just remember...Tri Glide needs to be greased quite often...
True, that's one of the reasons it could be improved on.
It, initially, was a bit of a bother, but, since it only has to be done every 1K miles it isn't a "constant" bother. I got a Lincoln rechargeable grease gun that travels with us and it is only a minute or two, once or twice a week to hit the zerks with a single trigger pull. I work it in with a thorough inspection of the rest of the trailer prior to pulling out. We're retired and usually only cover about 1K miles per week, sometimes is takes us longer to cover a thousand miles, so, it isn't like a "constant" bother. That all being said, though, it would be nice if they could figure out a way to use sealed bearings in the Tri-Glide device to eliminate the greasing altogether. It is much cheaper for them, though, to use zerks and put the onus on the user...
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
