P Kennedy wrote:
If I understand your scale results there was a difference of 460 lbs between right and left on the same trailer axle?
Correct, the numbers are oriented as if you were looking down from the sky at the 4 tires. Even front to back there was a variation of weight, which I was surprised with.
All the weights were within D range ST tires but not by a lot. Still debating if I want to upgrade to 16 rims or just go the easy way with ST tires. I was planning on upgrading via a new trailer but that is on the back burner now :(
I used a scale on the side of the highway and just moved the truck and trailer around, me and the wife and the 2 dogs were in the truck.
