A GFCI works by comparing the current in the return leg of power to the ground leg's current. If any item is working correctly the ground carries NO current, all current is in the hot and neutral legs. So Something is shorted to ground and allowing current to flow through it. Start by having everything on and as you turn off breakers check the GFCI to see if it will stay on. When it does, the last circuit you powered off has the fault. If you have everything off and it still trips then it is a weak GFCI and needs to be replaced. It could be as simple as one of the devices YOU plugged in (BUT it must have a three prong plug to be involved, two prongs do not use the GFCI) or in installed item (water heater, refrigerator, microwave or even the surge protector or the inverter for your battery charging). Good luck with finding it. Can you use the trailer with it off? Yes but something will not be working when it should.
