drummer2020's avatar
drummer2020
GFCI at shore power tripping
Hello Everyone. Brand new to this. Hopefully someone can help me out. I have a 2021 Amerilite 199DD travel trailer. I inadvertently drained the hot water tank for winterizing and thought I had the switch off but I did not. The element failed of course. The GFCI on the shore power tripped to alert me. I went ahead and installed a new element, but alas, the GFCI tripped again after a few hours. I went ahead replaced the converter thinking that that may have been damaged in the element failure but still, the GFCI tripped. At this point, I isolated it down to the "GEN" circuit. When this one is in the "off" position, the GFCI at the shore is not tripping. I have a 30 amp to 15 amp plug adapter for the power source and have been using this for the last 3 months with no issue until the element failure, for information sake. If someone has some words of wisdom that would be super. Thanks!!
Having RV issues? Connect with others who have been in your shoes.24,228 PostsLatest Activity: Apr 02, 2025
