I have a 2006 Crossroads Cruise 5th wheel. I have a GFCI that is tripping and killing the circuit. The breaker does not trip and the fuse does not blow. I changed the GFCI and I get the same result. A...
Roy--Thanks for the suggestions. I am currently using the standard RV electrical cord supplied with the 5th wheel. It is plugged into a surge protector, which is plugged into a dedicated 30amp RV receptacle. The frige is plugged into a 15 ft, 14 Ga extension which is plugged into a 20 receptacle in the garage. I checked the receptacle with the plug-in analyzer. Both of the receptacles check out OK. I'm still scratching my head.
