Don_in_LAExplorerJul 28, 2013Tripping GFCII have a 2006 Crossroads Cruise 5th wheel. I have a GFCI that is tripping and killing the circuit. The breaker does not trip and the fuse does not blow. I changed the GFCI and I get the same result. A...Show More
drfifeExplorerOct 03, 2013I had a same symtoms on a previous trailer.The bus bar had worked slightly loose.Unplug from shore power and make sure the bus bar screws are tight.
Related ContentNo power on outside GFCI outletGFCI at shore power trippingGFCI Keeps TrippingNavion 24 trips GFCIstrip directions to avoid tunnels
