I have a 2006 Crossroads Cruise 5th wheel. I have a GFCI that is tripping and killing the circuit. The breaker does not trip and the fuse does not blow. I changed the GFCI and I get the same result. A...
FYI I have never seen it happen but others have. If the neutral (white wire most cases) and the green grounding conductor are touching at some point that can cause in some cases a trip. Never saw it others have.
