Don_in_LA's avatar
Don_in_LA
Tripping GFCI
I have a 2006 Crossroads Cruise 5th wheel. I have a GFCI that is tripping and killing the circuit. The breaker does not trip and the fuse does not blow. I changed the GFCI and I get the same result. After filling the circuit and changing the GFCI, the circuit worked with a moderate load for about 30 minutes then the GFCI tripped again. I attempted to reset the GFCI and it immediately tripped again. The circuit was showing the same symptoms previously and then started working normally and then, again, started tripping. The GFCI seems to be the 1st in the circuit. There is a hot line coming in and a load line going out of the box. All other circuits function when the GFCI trips. The only other anomaly is occasionally the 12v lights will dim briefly. Any thoughts?
  • PS: If I kill the circuit by turning off the breaker, will it be safe to use the other circuits until I can get it fixed?
    Thanks,
    Don
