Kevin8520
Oct 20, 2015Explorer
Hi Don, I don't know the current amp hour rating on the one battery. I will pull it from the battery box and find out asap.
I would prefer not to add an additional solar panel at the moment if possible. I do have a generator onboard and I do also camp at campgrounds with full hookups. With those two additional power sources do you still feel 275 worth of solar is needed?
I see you have a hefty battery bank. Admittedly I don't know a ton about solar. Would an additional solar panel connect to the one already on the roof or does it need to be wired down to the charge controller?
About Fifth Wheel Group
