rivalrider
Oct 21, 2015Explorer
Kevin8520 wrote:
Hi Don, I don't know the current amp hour rating on the one battery. I will pull it from the battery box and find out asap.
I would prefer not to add an additional solar panel at the moment if possible. I do have a generator onboard and I do also camp at campgrounds with full hookups. With those two additional power sources do you still feel 275 worth of solar is needed?
I see you have a hefty battery bank. Admittedly I don't know a ton about solar. Would an additional solar panel connect to the one already on the roof or does it need to be wired down to the charge controller?
You should be able to add another panel just by connecting them together on the roof. You do however need to find out how many watts your solar charge controller is capable of though first.
-Tyler
About Fifth Wheel Group
