pianotuna
Oct 21, 2015Nomad III
Kevin,
Yes you still need 275 watts minimum.
Just parallel connect the additional panel on the roof.
I used to have 875 amp-hours of flooded batteries and used bank switching to save on solar costs, back when panels were "cheap" at $5.50 per watt.
Kevin8520 wrote:
I would prefer not to add an additional solar panel at the moment if possible. I do have a generator onboard and I do also camp at campgrounds with full hookups. With those two additional power sources do you still feel 275 worth of solar is needed?
I see you have a hefty battery bank. Admittedly I don't know a ton about solar. Would an additional solar panel connect to the one already on the roof or does it need to be wired down to the charge controller?
About Fifth Wheel Group
