golf_bears wrote:
If the dip stick shows full and the engine is frozen (won't turn over) your oil pump is the problem. If the engine froze then it will have to be replaced.
sounds like you may be onto something I'm pretty sure they put the warning lights and things on there for a reason
And,,, if you get the warning and you continue to drive maybe the engines not getting oil
just a thought here......
If the oil pump Failed,and you drove TEN MILES towing the 5er....You may have siezed the motor...Burned the bearings, shot crank,Cylinder walls,pistons,rings, rockers.....$$$$$$$$$
YIKES....
Do you have a place near home,that you trust???????
Either way,does not sound good.
