laknox
Oct 01, 2013Nomad
Miles Away wrote:
If all else fails, consider the possibility that you may have a "high pinning" issue. You may have raised the trailer too high before unpinning and it is lifting up on the hitch and holding it in place. Try leaving a little weight on the hitch and let it slide off as you pull forward.
I agree. Your FW should slide down about an inch and rock the hitch head back as it slides off. You want to reverse this process when you hitch; let the pin slide =up= the hitch as you back in, pressing the truck =down=. Again, 1-2" are all that's necessary.
Lyle
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
