RCMAN46
Oct 01, 2013Explorer
Quick trip wrote:
Try chocking the fiver first and then put the truck in NEUTRAL, let the truck settle for a minute and then try to release the handle!
Good Luck & Drive Safe!
But do not release the hitch with the truck in neutral. You may be chasing a truck down the road. Always chock the trailer before unhitching or you may have a trailer going down the road.
I raise my 5th wheel and watch the hitch plate. It will move a little as the weight is removed. There should not be any gap between the hitch plate and the king pin plate. If there is you are too high. Also as mentioned best to have a little pressure in reverse when you put it in park. If there is any forward pressure the hitch will not release.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
