rhagfo
Oct 02, 2013Explorer III
RCMAN46 wrote:Quick trip wrote:
Try chocking the fiver first and then put the truck in NEUTRAL, let the truck settle for a minute and then try to release the handle!
Good Luck & Drive Safe!
But do not release the hitch with the truck in neutral. You may be chasing a truck down the road. Always chock the trailer before unhitching or you may have a trailer going down the road.
I raise my 5th wheel and watch the hitch plate. It will move a little as the weight is removed. There should not be any gap between the hitch plate and the king pin plate. If there is you are too high. Also as mentioned best to have a little pressure in reverse when you put it in park. If there is any forward pressure the hitch will not release.
I do this every time I unhitch! I do set the Parking Brake, something most with automatic transmissions have forgot about! Never had to chase the TV down the road.
I never raise the 5er to remove all the weight from the truck. I take some of it off, but not all the truck will rise about 1" as I pull forward.
When you hitch the pin plate should be 1" to 2" lower than the hitch plate and ride up as you back in, this will prevent "High Hitching".
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
