ETCrockett
Jun 19, 2017Explorer
Update on the slideout motors running backwards on Lippert system. I got some great advise here. I finally found a good manual on the lci.com site and found out there are dip switches for changing the motor direction on the command module in the event the wiring is crossed. Sounds like Lippert planned for this issue with a built in remedy. Once I flipped the switch to get the motors moving in the same direction, everything worked fine! Issue solved! On to the next!
Thanks,
Thanks,
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
