Noles17's avatar
Noles17
Truck Advice
Evening all,
I am looking for a little truck advice. I currently have a travel trailer and am looking at upgrading to a 5th wheel by the end of the year. My current truck, Ram 2500 with 5.7, won't pull the fiver so obviously I am going to upgrade there as well.
The 5th wheel we are looking at weighs around 15.5K lbs. I understand that I need a 1 ton, or its just the better option, but I do not want this size truck as my daily driver anymore. I am considering getting something to have as a utility truck and just to pull the 5th wheel. Any recommendations for under 20K? I am seeing a good bit of options in a F350, around 2004 or 2005 model years, with under 100K miles.
What are your thoughts?
  • md_procouple wrote:
    We have had our 2006 F-350 for 4 yrs, (dreaded 6.0, as one person stated) and never encountered a problem. We pull our Montana without any problems. Good Luck and Happy Camping !!
    X2, same year & model. It only had 28k miles on it when I bought it in 2013 after a whole lot of research. First thing I did was get the cooling system power flushed and added a coolant filter. We've put 30k miles on it, crossed the US twice, and only had minor problems.
  • 100k miles on a diesel is nothing, so I wouldn't worry about that being a deal breaker.
  • Early Rams in 07 were still the 5.9 Cummins. The newer emission laws kicked in with vehicles produced on or after 1/1/2007.
    There are a few reasons so many Fords diesels are for sale with the 6.0. The first is that they outsold the GM and Dodge diesels in those years 2 to 1 combined. The second is that they are ticking time bombs. Those that never had a problem are few and far between, and when they do look out $$$$$$.
    Sorry Ford guys, I really wanted one but the evidence is over whelming.
  • Thanks for the advice so far.
    Yes, the plan was to definitely get the duely. Just wanted to make sure that as along as I found one with under 100K miles that I wasn't completely crazy
  • Some of various forums will advise a huge truck - usually more than needed. You can't go wrong that way, but read the specs including weights on your rig and prospective trucks and make your decision based on that.
  • We have had our 2006 F-350 for 4 yrs, (dreaded 6.0, as one person stated) and never encountered a problem. We pull our Montana without any problems. Good Luck and Happy Camping !!
  • rhagfo's avatar
    rhagfo
    Explorer III
    Just saw a 2008 Ram 3500 DRW nearby for an asking price of $31,995, with 94,000 miles, about 11,700 miles a year. If it was a 2007, likely the asking price would be the same.
    In the year range you are looking likely more likely 125,000 to 200,000, if maintained even 175,000 isn't too bad.
  • corvettekent wrote:
    Emissions started in 2007 on diesels so any of the Chevy, Ford or Dodge diesels before that would be good. Get a duely.
    Or an early '07 GMC with LBZ Duramax.
    Lyle
  • Emissions started in 2007 on diesels so any of the Chevy, Ford or Dodge diesels before that would be good. Get a duely.
  • 2004 05 Ford diesels will be the dreaded 6.0. That is the reason there so cheap. The motor is basically junk. What you will need for a 15K fiver in an older truck will be a dually. Nothing less is going to comfortably handle that much fiver.
