Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
352 wrote:. A DRW will have a higher payload rating than a SRW. This is what counts when towing a 5th wheel. If you're referring the weight comment to pulling power, the difference is minor, but as stated, not the reason for a DRW. Most DRW have a higher axle gear ratio to make up any difference in the trailer weight limit. Decision on SRW vs DRW for a 5th wheel depends on total payload (pin weight plus cargo) not towing capacity.MTPockets1 wrote:352 wrote:?????? And, Abraham Lincoln invented the Internet.
Stability only. Weight capacity is less on a dually.
HAHAHA. DO THE RESEARCH
