Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
transamz9 wrote:Veebyes wrote:
Eleven pages worth & counting! HA! This is like 'Which anchor is best?' on a cruising boat forum.
The answer is the same. If you don't have enough for the the worst case scenario that suddenly you are faced with, you have bought the wrong one. If you bought anchor suitable for a 25' boat in extreme conditions & your boat is 35' do not be surprised if it drags & you are on the rocks.
Likewise, if you get hit with a huge gust of wind broadside with your SRW & get blown over, don't be surprised. That extra stability of the wider DRW could very well have kept you upright. Physics.
In that split second of your world getting turned over, thinking 'I should have bought a DRW' is too late.
The wind must be different around here. It blows my DWR truck around empty just like it does my srw. My drw truck weighs about 3500# more too. Go figure.:S
Cummins12V98 wrote:
Mad
All fine and dandy but IMHO you are WAY light on 18.3% pin.
When you load most 5er's a lot of the weight goes to the pin.
thomas201 wrote:
Get the right tools for the job. I like to use my truck as a moderate 4WD at our destinations. A dually just is not that good in the mud, or on narrow roads. So, I am backwards from most folks. Our 5ers will always be towable by a SRW and it will be a super cab with a standard bed. This is about as big a truck that I can manage on crappy roads. Of course this is the type of company truck I used in the oilfield. Your Mileage may vary.
dezl_dr wrote:
Justification at it's finest, both sides of course. I'll kick this horse again.
The reason for DRW, more capacity, simple as that. You have the same drive train other than the rear axle. Sure they beef up the springs and frame, and adjust the front rear brake balance.
As for a drw being to big for the roads, might want to look at the trucks that built the road, pave the road, gravel the road. Install the electric to the homes. Hint, all DRW.
When a 1 ton isn't big enough they build the F450, F550 or your brands equal. That isn't enough? well no problem, we can all go class 8 if we want/need to.
So that's it, if you need the weight rating you should buy a DRW. If you can axle it out with a SRW go for it. But for my fiver unless they start making super singles you can't/shouldn't try a SRW truck. My DRW barely makes the ratings on the scales and for this discussion the scales don't lie.
My .02
