Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
transamz9 wrote:avvidclif1 wrote:wesdlewis wrote:
I have owned both, I have a 40 ft 5th wheel and a SWD (3500) now there are a few differences the stability is not as good and the brakes are smaller. I would never buy another SWD, stick with the DWD.
With a 40' 5th wheel you are probably over on all the ratings for a SRW 350/3500. And then wonder why it isn't stable and you need DRW. Duh
And you are 100% sure on this?
This truck handles the weight just as good as the truck in the next picture.....
transamz9 wrote:Cummins12V98 wrote:transamz9 wrote:avvidclif1 wrote:wesdlewis wrote:
I can tell you what truck I would rather be driving in a downhill panic lane change!!!
I guess if someone didn't know any better and just judged a book by it's cover then they would pick the truck with six wheels on in. I will tell you this. It is amazing what you can do if you place the correct "band-aids" in the correct place.:W
If you look closely also you will see that they both have the exact same band , model , and size tire on them. One just has two extra on the rear. Both trucks also have a 2" lift under the fronts.
Do you see the word "PROBABLY" in my post???
Handling the weight(???) and being over recommended weights are 2 different things. Why not post the weights and ratings and see what they look like? Be interesting.
