j09789ExplorerDec 24, 2017Truck tire pressure.Recommended cold PSI is 60 front & 65 rear. They are Michelin 275/65/20 load range E on a 2017 F250 Power Stroke. Should I increase the pressure when towing my 39' toy hauler (Triton by Voltage)?
atwowheelguyExplorerDec 24, 2017Here's the inflation table. You have to determine the weight on your axles by taking it to the scales.60 psi will carry 6060 lbs. per axle.65 psi will carry 6390 lbs. per axle.Front GAWR could be 4550-5600.Rear GAWR should be 6340.Those standard pressures will handle any load up to the limit on the axles.What is the front and rear GAWR on your truck?
