Recommended cold PSI is 60 front & 65 rear. They are Michelin 275/65/20 load range E on a 2017 F250 Power Stroke. Should I increase the pressure when towing my 39' toy hauler (Triton by Voltage)?
When towing, I always inflate the truck tires to 80 to get max capacity. When not towing, the recommended pressures are fine. Same thing with trailer tires, they are always inflated to max rated psi. Low pressure creates heat, which will destroy a tire sooner or later.
