j09789
Dec 24, 2017Explorer
Truck tire pressure.
Recommended cold PSI is 60 front & 65 rear. They are Michelin 275/65/20 load range E on a 2017 F250 Power Stroke. Should I increase the pressure when towing my 39' toy hauler (Triton by Voltage)?
DReisinger wrote:
I am running Goodyear,Load rang G, 19.5" on my Dodge Dually at 110 lbs. Bring it On
atwowheelguy wrote:
Here's the inflation table. You have to determine the weight on your axles by taking it to the scales.
60 psi will carry 6060 lbs. per axle.
65 psi will carry 6390 lbs. per axle.
Front GAWR could be 4550-5600.
Rear GAWR should be 6340.
Those standard pressures will handle any load up to the limit on the axles.
What is the front and rear GAWR on your truck?
azdryheat wrote:
My sticker says 70 front and 65 rear and that's what I run. Tires been wearing fine.
GordonThree wrote:
Hmm, I guess I figured Michelin would follow suit with the other big brands but seems not. Can't find a current published inflation guide for that size tire. They only cover 16, 17 and 18".
