laknox
Feb 05, 2020Nomad
Trumpetgolf wrote:
Help requested. Newbie just getting setup. Got a Durango 1500 5th wheel and a 2014 F-350 LB crew cab. I figure the truck is too tall for the RV. Have a Reece 15K Pro Series hitch not yet installed per rails. I see four ways to fix: 1. raise RV at axel, 2. go to 16" tires, 3. level truck, 4. change king pinbox. Anyone have other solutions? Thanks
First off, I haven't seen a new FW in several years that didn't already have the axles under the springs, or "flipped". That being said, some mfrs install spring hangers with adjustment holes for this purpose. Check and see if the springs (and equalizer) have extra holes lower than the springs.
With a LB truck, you shouldn't have to worry about the rear of the pin box contacting the bed sides, but =do= check.
16" tires will get you =maybe= 0.5 to 0.75 inches of lift. Much beyond that and you can run into wheel well clearance issues.
Assuming you have a stock truck (no lift), check to see if you have blocks in the suspension that can be removed to lower the truck.
Some people would install the Correct Track alignment system, which gives a 2" lift to the FW, but I believe they are no longer being made, so may be hard to find.
If you're still 2-3" nose high, and have a minimum of 6" of bed clearance, I'd say go camping. That little bit off level really won't hurt things, IMO. I towed close to 4" nose high on my old Komfort for 13 years and the fridge worked fine, wheel bearings showed no significant wear (front or rear) after 10 years and I had no odd tire wear on either axle.
Remember, too, that your truck will squat some, so that will also reduce any nose-high issue.
Lyle
About Fifth Wheel Group
