Arcamper wrote:
I put mine in the front bay and yes it has a light that blinks when it gets a signal from the wheel sensors. Works very well on our Montana/Ram combo.
If it blinks once when you get a signal from a wheel sensor that will occur about every 5 minutes. The wheel sensors send signals about every 5 minutes.
If this is true you can determine if the repeater is receiving all of the sensor signals. If you have ten sensors as I have you should see 10 blinks in a 5 minute time period.
Myself I have found an external antenna mounted under the TV on the receiver hitch works best when towing a 5th wheel with a utility trailer behind the 5th wheel. Does not require a power source and is completely weather proof.
