fj12ryder wrote:
I'm sorry 93Cobra2771, but I'm right and you're wrong. :)
Removing the sensor while it is in contact with the monitor will sound an alarm because it shows low/no air pressure. Now leave the monitor on and the sensor in place, and drive/walk away with the monitor, from the trailer/sensors . Make sure you are out of range, the best test is to go out to eat or shopping so you're plenty far away. It will be around an hour before you get an alert that the monitor has lost contact with the sensor.
This is the way the system is designed, and IMO is the only real flaw in the TST TPMS. That is the reason they recommend a repeater if you have a long trailer/5th wheel. If you ask them about this they will tell you it is operating as it supposed to.
Earlier this year I was leaving Harrison, Arkansas, after a stay of a week. I rarely check my TST monitor, relying on the alert to make a problem known to me. On an open stretch of hiway I happened to notice that I had one tire that was 10 psi lower and about 15° cooler than the other 5. I started looking for a place to pull over to check things out, when the pressure and temperature were now both in line with what the other tires were showing. What had happened is that the one tire was still showing the temperature and pressure from when I had first left the campground, about an hour before. It had been out of contact with the monitor all that time.
I have ran this test and fj12ryder is correct. After an hour, I finally received an alarm that communication had been lost.
