Lantley
Jun 15, 2016Nomad
BarneyS wrote:N-Trouble wrote:IdaD wrote:rhagfo wrote:
Even at 30' to 33' a 5er is a big advantage, FAR more stable, inherently more stable!! With a TT even with a Hensley when the deification hits the rotary oscillator, the true pivot point is still 3' to 4' behind the rear axle! That will push the back one way and force the front the other way. I took too many engineering classes in school.
The step issue, I partly solved our issues by adding steps! Made each step smaller. added a step into the bedroom level and replace the three step entrance with a four step that all the risers are the same height.
Some of the TT guys swear up and down that the Hensley type hitches make their travel trailers tow the same as fifth wheels and those statements have never made sense to me. I guess I've never tried to understand the physics of it, but at the end of the day it seems to me that your physical attachment point is still 4' behind the rear axle and your travel trailer is still lighter on the tongue than a fifth wheel is on the pin. But I admit I've never used that kind of a hitch.
Those are TT guys that have never towed a 5er.
Not true! I have done both and the TT with the Hensley tows every bit as well as the 5er ever did.
Those that do not understand how this is possible might want to take a long look at, and study this thread. :)
Engineering classes notwithstanding, the true pivot point is never 3' to 4' behind the rear axle.
Barney
X2^^
As mentioned in my first post. The towing advantage of the 5'er is overstated. My 39" 11K GVW TT towed just as well as my current 5'er.
It did take a lot more effort to get the TT dialed in. But once I discovered the Hensley my TT was rock solid. Just as solid as my 5'er
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
